The single chip embedded Linux board
Sold By petit_minerNo shipping info available.
The development board features: Ethernet Jack Micro USB port FFC for MIPI CSI FFC for DVP (parallel CSI) FFC for all 40pin parallel RGB displays Wifi (ESP8089), antenna included Audio jack (3,5mm…
Read More…The development board features:
Processor Specs:
SD / MMC Interface
PWM
up to two PWM channels
up to 24 MHz output frequency
Video output
Camera
Still capture resolution up to 5M with parallel interface
Video capture resolution up to 1080p @ 30fps with parallel interface
Audio codec
two audio DAC channels
one differential microphone input
one stereo headphone output
one low-noise analog microphone bias output
USB
One USB 2.0 OTG controller with integrated PHY
Support High-speed, Full-speed and Low-speed in host-mode
Ethernet
Integrated an internal 10/100M PHY
support full-duplex and half-duplex operation
UART
SPI
I²C
up to two I²C controller
support Standard and Fast mode
BROM
The integrated bootloader can boot from a SD card / SPI Flash (NAND / NOR)
Softwaresupport (Linux Kernel)
The support of mainline U-boot and mainline Linux kernel is in good progress. You find all the details at the Linux mainlining effort at sunxi.
The mainline linux kernel (5.1) has support for:
Whats not implemented:
Enter your email address if you'd like to be notified when Dolphin Pi / Allwinner V3s development board can be shipped to you:
$399.00
$299.00
$299.00
$192.99
