A male-female jumper wire made with 24 AWG silicone wire and gold-plated connectors for a heat-resistant, durable, and tight connection.
Designed by BST in Poland
What is it? It is a male-female jumper wire created with use of 24 AWG silicon wire, and golden plated connectors. Why did you make it? I was not satisfied with quality of widely available jumper wir…
Read More…It is a male-female jumper wire created with use of 24 AWG silicon wire, and golden plated connectors.
I was not satisfied with quality of widely available jumper wires made with ribbon cable. It was often place where the bug was hidden, and I lost too much time on finding it.
It is made with high quality 24 AWG silicon wire, the diameter is selected so it tightly fit space within connector casing which gives you robust connection. Silicon insulation is heat resistant, even soldering iron would not melt it. Golden connectors gives better overall connection and longevity.
Enter your email address if you'd like to be notified when Jumper wire male-female silicon 20cm 2.54mm 6pcs can be shipped to you:
$34.95
$6.99
$10.99
