4 Decade Inductance 100nH – 1mH (High Power)
Designed by PNP Instruments in United States of America
The 4 Decade Inductance Box offers precision with selectable inductances from 0.1μH to 1mH. Ideal for various applications, it handles up to Experience precision and flexibility with the 4 Decade Ind…
Read More…The 4 Decade Inductance Box offers precision with selectable inductances from 0.1μH to 1mH. Ideal for various applications, it handles up to
Experience precision and flexibility with the 4 Decade Inductance Box, featuring four selectable decades ranging from 0.1μH to 1mH.
Each toggle switch, when ON, adds its inductance value into the circuit via banana jacks, terminal blocks, or headers. When switched OFF, the inductance is effectively isolated from the circuit.
This versatile tool is ideal for a range of applications, including design, development, debugging, and educational endeavors. It offers a multitude of connection options, allowing users to interface with ease.
Capable of handling currents up to 2A for inductance values between 0.1μH and 100μH, with specific current limits outlined in the datasheet for values exceeding 100μH.
Inductance range: 0.1μH to 1mH. Currents: Maximum 2 Amp Max DC/AC Voltage: 100Volt Switch Resistance 100mΩ Max
Connector Options: - 5mm pitch Terminal Block: Accepts 26-14AWG solid core wire - 2-pin header: Accepts 2.54mm 2-pin/individual female pin headers - 4mm Banana Terminal: Compatible with off-the-shelf banana plug cables. Also can accommodate common Banana to BNC adaptor
Unit Dimensions: 75.1mm x 53.6mm x 20.7mm
Unit Weight: ±94g
Specifications:
Range | Tolerance | DC Resistance Typical (DCR) | Max Current |
0.1μH | 20% | 7mΩ | 2A |
0.2μH | 20% | 14mΩ | 2A |
0.3μH | 20% | 21mΩ | 2A |
0.4μH | 20% | 28mΩ | 2A |
1μH | 20% | 41mΩ | 2A |
2μH | 20% | 123mΩ | 2A |
3μH | 20% | 82mΩ | 2A |
4μH | 20% | 164mΩ | 2A |
10μH | 20% | 64mΩ | 2A |
20μH | 20% | 128mΩ | 2A |
30μH | 20% | 192mΩ | 2A |
40μH | 20% | 256mΩ | 2A |
100μH | 20% | 272mΩ | 2A |
200μH | 20% | 544mΩ | 1.8A |
300μH | 20% | 816mΩ | 1.6A |
400μH | 20% | 1.088Ω | 1.4A |
Higher Inductance Settings | Inductance | Settings| Max. Current | | -------- |: --------|:--------:| | 500μH | 400μH+100μH | 1.2A | | 600μH | 400μH+200μH | 1.1A| | 700μH | 400μH+300μH | 1A | | 800μH | 400μH+300μH+100μH | 0.9A | | 900μH | 400μH+300μH+200μH | 0.85A | | 1mH | 400μH+300μH+200μH+100μH | 0.8A |
Note: Do not exceed the listed currents for the given settings!
Enter your email address if you'd like to be notified when 4 Decade Inductance 100nH – 1mH (Max. 2 Amp) can be shipped to you:
All shipments, by default, will be handled by USPS. All orders received before 12pm (PST), will be shipped out the same day. A tracking code will be provided.
For International packages, please check with your own country's customs regulations before purchase. We will fill up all the customs-required information when we ship out but we do not handle custom clearance at the destination country.
$140.00
$95.00
$106.00
