5 Decade Inductance Board 0 nH to 1 mH, in steps of 10 nH. With 3 different connector types for quick integration.
Designed by PNP Instruments in United States of America
Debug, prototype, and design faster with less hassle than using individual inductors. This board is the smallest decade board you will find on the market without sacrificing limited bench space. Most…
Read More…Debug, prototype, and design faster with less hassle than using individual inductors. This board is the smallest decade board you will find on the market without sacrificing limited bench space. Most decade boards/boxes are just TOO BIG to put next to your proto boards and the million other things found on a working bench.
5 Decade Inductance Board provides inductance from 0 Henry range to 1m Henry range in an ultra-small space to not get into your way.
You can quickly select an inductance range to quickly debug circuits or use it as a reference to test instruments.
The dual banana plug allows users to use a time-saving banana-to-BNC converter to quickly connect to subsequent circuits.
** • Board allows the user to select any inductance from 0 nH to 1 mH in steps of 10 nH.
• Users can quickly select a desired inductance range to quickly debug circuits or use a reference to test instruments.
• Dual banana plug allows users to use a time-saving banana to BNC converter to quickly connect to subsequent circuits.
• 2 pin header can be used alternately or a 2-pin terminal post.
Board : 61mm x 40 mm x 22 mm •2 pin male 0.1″/2.54mm header
•2 pin 0.1″/2.54mm terminal post
•2 banana plug 0.75″/19.05mm
Color: Blue
Materials: FR4
Weight: +26.1g
Shipping Details: We ship out the order the same day for orders made before 12pm PST. Ship via USPS
Enter your email address if you'd like to be notified when 5 Decade Inductance Board 0 H - 1mH (with Cover) can be shipped to you:
All shipments, by default, will be handled by USPS. All orders received before 12pm (PST), will be shipped out the same day. A tracking code will be provided.
For International packages, please check with your own country's customs regulations before purchase. We will fill up all the customs-required information when we ship out but we do not handle custom clearance at the destination country.
1-4 | $50.00 |
5-9 | $47.00 |
10+ | $45.00 |
$120.00
$140.00
