Tilswall Paint Sprayer 800 watt power,1300ml capacity with 3 different sizes nozzles to meet any tasks.
Designed by Tilswall in Germany
【800W &1300Ml】✤Split motor and spraying handle to reduce the handheld weight and 8.2ft/2.5m premium tube brings more flexibility of your spraying✤With 800 watt power, 1300ml capacity, Tilswall paint …
Read More…【800W &1300Ml】✤Split motor and spraying handle to reduce the handheld weight and 8.2ft/2.5m premium tube brings more flexibility of your spraying✤With 800 watt power, 1300ml capacity, Tilswall paint sprayer improve atomization effect to reduce overspray and highly customize to fit to your painting work, match covering speed and project size, performing a top-notch quality of work.
【 Max 1100Ml/Min】Never Compromise In Features And Quality! A variable air pressure control from 0 to 1100ml/min allows you to change the force the sprayer uses to release paint, finish the earliest possible time with a substantial horsepower. Both for home interior use and exterior use.It is suitable for spraying alcohol and other liquid disinfectants.Stair handrails,tables,conference rooms and toilets can be disinfected during the COVDI-19.
【 3 Spray Patterns & 3 Size Nozzles】 Horizontal? Vertical? Circular ? All covered! With additional 3-size nozzles(φ1.0mm、φ1.8mm、φ2.6mm) ) for higher accurancy to any painting projects. Suitable for spraying latex paint, water- and solvent-based paints, finishes, primers, 2-component paints, clear finishes, automotive finishes, staining sealers and wood sealer-preservatives.
【 9.84Ft Cable & 120 Din/S】9.84Ft/3m cable increases more accessibilty when you need more mobility; 120din/s supports high visocity for avoiding clopping easily which will cause the gun to spit and sputter, even for latex paint. Great for decks, fences, furniture, trim, sheds, railings and garages.
【Easy To Wash & Package Contents】Tank can be detachable and mouth is big enough for washing. What will you get? 1 x 800W paint gun with 3M cable, 1x 1.4M shoulder straps, 1 x 2.5M hose, 1 x funnel, 1 x 1300ML container, 3 x nozzles, 1 x cleaning needle, 3 x gaskets, 1x cover, 1 x cleaning brush, 1 x English user manual. If you have any quality problem within 28 MONTHS, please feel free to contact us. Tilswall devotes to serving for you!
✔High efficiency 800W Paint Sprayer with large detachable 1300ML container and 8.2ft/2.5m premium tube brings more flexibility of your spraying.
✔It is equipped with an adjustable valve knob allows adjustable flow control from 0 to 1100ml / min for decks,fences,furniture,sheds,ramps and garages.
✔Maximum viscosity of 120din / sec,the paint passes through a strainer to make sure it does not clog the nozzle.
✔Equipped with 3 different sizes nozzles ( Φ1.0mm, Φ1.8mm, Φ2.6mm) to meet any tasks.Suitable for table, Chair car, shutter and any wood furnitures.
✔There are multiple accessories: 1 x 800W paint gun with 3M cable, 1x 1.4M shoulder straps, 1 x 2.5M hose x funnel, 1 x 1300ML container, 3 x nozzles, 1 x cleaning needle, 3 x gaskets, 1x cover, 1 x cleaning brush, 1 x English user manual.
Tilswall Paint Sprayer 800 watt power,1300ml capacity with 3 different sizes nozzles (Φ1.0mm, Φ1.8mm, Φ2.6mm) to meet any tasks.Suitable for table, Chair car, shutter and any wood furnitures.And suitable for liquid disinfectant for large area disinfection,you can stair handrails,tables,conference rooms and toilets can be disinfected during the COVDI-19!!
For more information, please visit our website: Tilswall Paint Sprayer
Enter your email address if you'd like to be notified when 800 Watt Home Electric Spray Gun Paint Sprayer can be shipped to you:
Free shipping on orders over €19.99
1 | $86.78 |
2+ | $86.78 |
$41.00
$650.00
$53.00
