12V 10A Battery Charger & balance module for 3x 18650 cells. Charger or Solar input Charge voltage 15V-24V 2h quick charge
12V 10A 3S 3x 18650 Lithium Ion LiPo Battery cell Charger & Balance module holder This battery module will manage efficiently and safe 3x 18650 lithium battery cells to give fully protected (underv…
Read More…12V 10A 3S 3x 18650 Lithium Ion LiPo Battery cell Charger & Balance module holder
This battery module will manage efficiently and safe 3x 18650 lithium battery cells to give fully protected (undervoltage, overcurrent, overvoltage, temperature) output 12V (12,6V) 10A max output. Max power out 125W. It can also recover dead cells or under working voltage cells.
You can use any kind of 18650 cells, reused cells from laptop or ups battery, low cost cells or high quality, high drain 1000cycle life cells (check options). Use this battery module plus optional voltage converter module to get any output from 1V to 60V 125W with USB out 6A max or 220V AC (see options)
Module highlights:
Overview:
The 3S 18650 Lithium battery charger & balance module is a charging and protection module for 3 pcs 18650 Lithium batteries. Can be used as portable 12V powerbank with solar or charger input. Includes MPPT charging function for solar input maximum efficiency. This module acts as an intelligent charger and supports any 15-24V power supply. Has four LED's to give battery status indication with a push of a button. The Lithium battery charger & balance protected module constantly monitors each cell voltage, current of charge, discharge and the temperature of the environment to provide overcharge, over-discharge, over current and over-temperature protections, etc.
Any other batteries chemistry, especially LiFePO4, are prohibited.
Please check the battery polarity before installation!
** See also links BELOW , many stuff interesting for you. *
See also tindie store below.
I have also other kind of cells and balancer for easy DIY battery assembly at low cost,if you need support at battery build please contact. Battery technology and development consulting to get the perfect battery.
Enter your email address if you'd like to be notified when 12V 10A BATTERY module 3x 18650 OUT 1-60V USB 220V can be shipped to you:
Documentation: (4.00)
Shipping: (3.00)
Mehedi | Feb. 8, 2019
$24.90
$40.95
$22.50
$29.80
$26.30
$19.90
$420.00
$17.00
