12V Dosing adjustable Peristaltic pump Aquarium Lab Analytical Water nutrient
One kit includes one unit 12V DC Dosing Pump Peristaltic motor 5000 RPM flow 5-100ml/min and one PWM motor controller with precise potenciometer. Aquarium Lab Analytical Water DIY plant nutrient, fis…
Read More…One kit includes one unit 12V DC Dosing Pump Peristaltic motor 5000 RPM flow 5-100ml/min and one PWM motor controller with precise potenciometer.
Aquarium Lab Analytical Water DIY plant nutrient, fish nutrient dosing etc Can be used for aquarium food dispenser , auto plant nutrition or laboratory water analysis where flow precison is required. Great precision flow even at low speeds. Can disperse drop by drop.
High quality motor Individual tested.
Feature: silent work
Suitable for aquarium, chemicals, liquids, dosing additives
The pump head designed for easy disassembly, easy to clean and maintain.
Has been widely used in the field of experimental, biochemical analysis, pharmaceuticals, fine chemicals, biotechnology, pharmaceutical, products, ceramics, water treatment, environmental protection.
Flow direction: you can control the flow direction by the positive and negative connect.
Specification:
Volts:DC12V
Working condition:0-50Celsius
relative humidity <80%
Flow rate: 5~100 ml/min
pump tube: Inner diameter : 3mm
Outer diameter : 5mm
Please check out my other spetecular items on my store. New items added every weeks. My Tindie Store here
Enter your email address if you'd like to be notified when 12V Dosing adjustable Peristaltic pump +controller can be shipped to you:
$24.90
$40.95
$22.50
$29.80
$26.30
$19.90
$16.80
$160.00
$720.00
