1KHz up to 33MHz signal source generator Oscillator
This oscillator will generate square wave any frequency from 1KHz up to 33MHz. It includes two precise potenciometers and divider selector jumper. Rail to rail output. Supply voltage from 2.7V to 5.5…
Read More…This oscillator will generate square wave any frequency from 1KHz up to 33MHz. It includes two precise potenciometers and divider selector jumper. Rail to rail output. Supply voltage from 2.7V to 5.5V. Easy to use and usefull tool in laboratory.
Specifications:
Operating Voltage: 2.7 to 5.5V DC. Operating Current: < 5mA. Operating Temp. Range: 0 to 70°C.
Design based on Linear Technology IC. Two 25 turns precision trimming potentiometer Terminal blocks, easy connection wire. FR-4 fiber glass material PCB ( double layer ). PCB size : 30 x 26.2 mm Maximum height : 15 mm
Fast Start-Up Time: <1ms +/- 40ppm/°C Temperature Stability 0.05%/V Supply Stability 50% ±1% Duty Cycle 1kHz to 2MHz 50% ±5% Duty Cycle 2MHz to 20MHz
100 Ohm CMOS Output Driver
Applications:
Low Cost Precision Oscillator , Charge Pump Driver , Switching Power Supply Clock Reference, Clocking Switched Capacitor Filters Fixed Crystal Oscillator Replacement, Ceramic Oscillator Replacement, Small Footprint Replacement for Econ Oscillators
EU stock. Shipped from Portugal. Quick delivery worldwide.
Please check out my other versatile items on my store My Tindie Products
Enter your email address if you'd like to be notified when 1KHz - 33MHz adjustable Signal Source Oscillator can be shipped to you:
$24.90
$40.95
$22.50
$29.80
$26.30
$19.90
$37.56 $46.95
$36.76 $45.95
$15.00 $25.00
