ultra low power ZigBee module autonomous operation possible firmware over the air. remote controls and read IO's 2.4GHz
Description Mesh Bee is a 2.4GHz wireless transceiver from seeed studio. It's based on NXP's newly JN516x series wireless microcontroller chip and supports ZigBee Pro network stack. The factory firmw…
Read More…Description
Mesh Bee is a 2.4GHz wireless transceiver from seeed studio. It's based on NXP's newly JN516x series wireless microcontroller chip and supports ZigBee Pro network stack. The factory firmware wraps the complicated ZigBee stack operation into a few easy to use serial commands, and drives Mesh Bee into a transparent serial communication node that can be part of a simple point-to-point connection or a complex mesh network.
Moreover, Mesh Bee is totally open hardware and open sourced, which means that you can customize the firmware on your requirements. You can use JN516x's ARM core to control things and JenOS to simplify your development. The development environment and tools from NXP are all free. Mesh Bee will bring you lots of fun.
Features:
Range: Indoor/Urban: up to 30m; Outdoor line-of-sight: up to 100m;
Receiver Sensitivity: -95dBm
Data Transmission Rate: 4800, 9600, 19200, 38400, 57600, 115200 (bps)
Working Frequency: unlicensed 2.4GHz band
Communication type: Point to Point or Start Network or Mesh Network
OTA support: update node's firmware on-the-air
Easy-to-Use Serial Interface and rich extendable ports
Easy-to-Use AT Command: Setup ZigBee network, Set Serial Baud Rate, etc.
Open source Hardware and Firmware
Programmable 32-bit RISC CPU: 32M clock, 256KB Flash, 32KB RAM, 4KB EEPROM
Socket compatible with the Xbee, so you can plug it into any Xbee socket as a quick replacement.
Specification:
Microprocessor :JN5168 (32-bit RISC CPU, 32MHz clock speed)
Resources :256kB/32kB/4kB (Flash/RAM/EEPROM)
PCB size :24.5mmx30.5mmx0.8mm
Outline Dimension :24.5mmx30.5mmx9.77mm
Indicators :No
Power supply :3.3V
IO counts :12
ADC input :3(2 multiplexing with IO)
Interfaces :UARTx2, SPI, I2C
Program interface :UART+MISO
Connectivity :Socket compatible with XBee
Communication Protocol :Uart (TTL)
Great community with well supported tutorials and help. Lots of fun for those who like wireless mesh networks and telemetry.
Package includes:
Resources:
MeshBee Google discussion group here
http://wiki.seeedstudio.com/Mesh_Bee/#5.2_How_to_update_firmware
EU stock. Shipped from Portugal. Quick delivery worldwide. Tracked shipping only.
Feel free to contact on any question about electronics , mesh networks , low power wireless or sensors LiFePO4 battery cell.
Enter your email address if you'd like to be notified when 2x Zigbee Pro Module w/ MCU Jenic JN5168 Mesh Bee can be shipped to you:
$24.90
$40.95
$22.50
$29.80
$26.30
$19.90
$140.00
$22.60
$32.80
