ATTINY85 miniature ARDUNO development board with Micro USB connector, on board 5V regulator Vin from 7 to 35V or USB
This amazing super small piece of art is ready to be used in your next projects! The micro-sized, Arduino enabled, usb development board comes with 6 IO's acessible to user. Supported by ARDUINO IDE …
Read More…This amazing super small piece of art is ready to be used in your next projects!
The micro-sized, Arduino enabled, usb development board comes with 6 IO's acessible to user. Supported by ARDUINO IDE to simplify your life. Just code and download to board! Ready to use IO's PWM ADC I2C SPI and a onboard regulator fixed to 5V (when using external supply) otherwise power is supplied by the micro USB connection. Board dimensions less than a square inch, more precisely 17*20mm High quality blue PCB and components
** Tech details *
Support for the ARDUINO IDE 1.0+ (OSX/Win/Linux) Power via USB or External Source - 5v or 7-35v (12v or less recommended, automatic selection) On-board 500ma 5V Regulator Built-in USB (and serial debugging). 6 I/O Pins (2 are used for USB only if your program actively communicates over USB, otherwise you can use all 6 even if you are programming via USB) 8k Flash Memory (about 6k after bootloader) I2C and SPI (vis USI) PWM on 3 pins (more possible with Software PWM) ADC on 4 pins Power LED and Test/Status LED
Any extra question feel free to contact
In stock 20 brand new units
Please check out my other spetecular items on my store My Tindie Products
Enter your email address if you'd like to be notified when AT TINY85 ARDUINO 2*1,7cm miniature MICRO USB can be shipped to you:
$24.90
$40.95
$22.50
$29.80
$26.30
$19.90
$16.99
