Power old ATX PC with battery input --> from 9V to 30V input to PC ATX
Do you want to convert PC to battery powered or solar powered? This two modules kit is tha solution! Kit includes: one DC/DC buck-boost converter module plus one precise ATX regulator module plus cab…
Read More…Do you want to convert PC to battery powered or solar powered? This two modules kit is tha solution!
Kit includes: one DC/DC buck-boost converter module plus one precise ATX regulator module plus cables connectors
TWO stage power converting --> first stage DC/DC module converter, wide input voltage range to stable 12V output. Second stage ATX 280W regulation module (due to DC/DC module limits use up to 65W TDP CPU example E8600 dual core, for more TDP power will need extra parallel DC/DC module converter to power quad core 95W TDP or 105W)
From 9V to 30V input at DC/DC converter input. Great for lithium battery pack 3S to 7S powered PC
Pictures example -> powering a intel E8600 1GB MSI sata HDD PC from a Lithium LiFe battery pack 12Ah 4S running windows about 30W power consumption at BIOS and full load consumption is about 60W
Shipped from Portugal express mail Protective mail package
PS: modules were used to test setup & adjusted to correct voltage/current. positive & negative wires soldered to DC/DC Thanks for your time.
Enter your email address if you'd like to be notified when Battery PC - DC/DC module + ATX regulator module can be shipped to you:
$24.90
$40.95
$22.50
$29.80
$26.30
$19.90
$10.99
$24.90
