Battery precise balancer 1,5A balance current. Quick balancing for new battery or battery pack with MIXED or reUsed cells
Are you lookin for a high efficiency, high current , quick balancer ( can replace BMS ) with almost zero power consumption for your battery pack? This is the solution! A precise quick balancing modu…
Read More…Are you lookin for a high efficiency, high current , quick balancer ( can replace BMS ) with almost zero power consumption for your battery pack? This is the solution!
A precise quick balancing module to build any kind of battery 12V / 24V / 36V / 48V / 60V NEW one or with USED / mixed capacity cells. Almost zero power consumption after balanced and very high efficient cell equalizer circuit. From 3 cells to 16 cells series. ( choose option or contact if you need any info )
With this balancer / equalizer it is possible to mix different cells in the battery pack
Balancer has a high current and quickly gets all those cells / cells block at equilibrium voltage. Keep real time balancing while using battery with an ebike or scooter or any kind of battery.
This balancer is perfect if you are going to build your electric bike battery pack with old reused mixed cells. Regular BMS just have 35mA around balancing current.. this module will do up to 1,5A at original BMS cable strip.(regularly this cable strips are rated up to 2A) When you have many used cells, those are different capacities and have different internal resistors. So, the solution is a balancer that can balance those different cells very quickly in an efficient way. After all cells are balanced, the module goes to sleep with minimal consumption, uA almost zero. Perfect.
Please choose option for you battery series configuration type. This balancer will work with any kind of cell chimique . This module does the job and just gets all cells at the same voltage quickly independent of cells type Lithium LiPo LiFePO4 Gel etc
Optimized circuit and high quality board / components. With top coating protective layer for PCB and components. Strip Cable connector included.
Please check options for your battery type. Default 3S
BATTERY TOPICS to increase cycles.
Wordwide shipping. Tracked and protective mail package
Future projects / modules
I will have more modules / projects related to E.V. / ebike / scooter. Example portable powerbank quick charging to give some extra juice to your ebike / scooter.
Performance module to easy connect and save your battery pack life cycles reducing peak current demand to your battery pack, this will be a energy buffer, results more torque, acceleration, more range, more battery life.
I will also have regenerative braking module to easy connect to 3 phases/DC motor & brakes signal of any ebike / scooter to grab regenerative braking energy with connector to battery to keep sending energy back. Will also do projects solar mixed with E.V.
If you have interest at this projects or want to support please feel free to contact.
Please check also my other store items. Maybe something useful or of your interest clicK here to visit my store
Enter your email address if you'd like to be notified when ebike scooter battery quick balancer 1.5A / cell can be shipped to you:
$24.90
$40.95
$22.50
$29.80
$26.30
$19.90
$48.33 $56.86
$420.00
$320.00
