0-60V 0-100A Digital LCD Display Voltage Current Power Battery Analyze Solar panel production analyser
High precision Energy analyser 0-60V 0-100A Measures Volts, Amperes, Watts, Amperes/hour, Watts/hour Medium Voltage and medium amperage Can measure battery energy supply and solar panel production. M…
Read More…High precision Energy analyser 0-60V 0-100A
Can measure battery energy supply and solar panel production. Measure battery real capacity. First charge battery 100%, than connect analyser and apply some load. Wait time to discharge all battery until safe level. Check the usefull Ah and Wh of the battery. This is the real usefull capacity of the battery.
Specifications:
Digital LCD screen gives clear crisp number readings.
Handles up to 100 amps intermittently and 50 amps continuous duty.
Connecting load end to the battery provides real-time battery charging reading.
Handles 0 to 60 volts. Works on 12, 24, 36, and 48 volt battery bank systems.
Extremely low power consumption of 7 mA. More efficient than any LED meter.
Measure energy (wh),charge (ah), power (w),current (A) and voltage (V).
Accurate & precise 0.01 A current and 0.01 V voltage resolutions.
Measures peak Amps, peak Watts (except for Doc Wattson) and Voltage minimum (sag).
Rugged- handles 50A continuous and 100 A peak at 60V.
Acts like a wire so doesn't affect model's performance. Precision Alu-Chrom current sensing resistor, with only 0.001 Ohms resistance and circuitry that draws only 7 mA.
Uses DSP to increase ADC resolution and differential measurement amplifiers to increase noise immunity. Specifications :
Color : Blue
Voltage : (0)V-4V-60V 0.01V (Resolution).
Current : 0-100 A peak 0.01A (Resolution).
Power : 0-6554 W 0.1W (Resolution).
Charge : 0-65 Ah 0.001Ah (Resolution).
Energy : 0-6554 wh 0.1 Wh (Resolution).
Measurement Update period : 400mS.
Signal Sampling Rate : sample/s.
Data Queue Sequence time : 2 seconds.
In Circuit Resistance : 0.001 Ohms.
Operation Current : 7 mA.
Auxiliary Power Voltage : 4.0V ~ 60V
Size : 8.3 x 4.7 x 2cm / 3.27 x 1.85 x 0.79inch
Display Screen : 1602 STN LCD
Package includes :
1 x Digital LCD Battery Analyzer
Tracked mail.
Please check out my other versatile items on my store. Maybe could be something of your interest. My Tindie Products
Enter your email address if you'd like to be notified when Energy analyser Watt metter Wh Ah Watts Volt Amp can be shipped to you:
$24.90
$40.95
$22.50
$29.80
$26.30
$19.90
$11.59
$15.99
$12.99
