Easy connection, low cost 128x64 0.96" OLED screen dispaly on top of ESP12-E breakout board.
Now is simple to display remote or local information on OLED display. Using base Wifi module ESP8266 ESP12-E easy connect to the web and get all information you need to be displayed. Can choose full …
Read More…Now is simple to display remote or local information on OLED display.
Using base Wifi module ESP8266 ESP12-E easy connect to the web and get all information you need to be displayed. Can choose full white OLED more visible area and more constrast, or dual color yellow blue (there is a non pixel line separation between colors) Future ESP library will support 65K color OLED.
Easy IO's direct connect to module VCC GND SDA SCL Exta IO's ADC, GPI00(flashing pull low with jumper/normal operation leave), GPI04, TX and RX pins. ESP module easy connection pin header. No need SMD soldering. Connect OLED display on top of breakoutboard. Small and compact. Purple PCB.
Basic OLED example ->
https://www.dropbox.com/s/fvsbwu6deb6u9ig/CODE.jpg
OLED WiFi Scanner ->
https://www.dropbox.com/s/qix8inmtpkv3q4i/code2.jpg
Many fonts available->
https://www.dropbox.com/s/dgv496mshz724h1/fonts.jpg
https://www.dropbox.com/s/hmaz1ewm3m0sc0a/modules.jpg
ESP is ready for deep sleep function. HW pin 16 tied to RST providing wake up. External IO0 for programming boot mode.
Example: node.dsleep(5000000, 4) --deep sleep 5 seconds, ultra low power consuption. Check all functions available here: NodeMCU API webpage
Program board from Arduino IDE:
Install latest Arduino IDE from the Arduino website.
Start Arduino and open Preferences window.
Enter http://arduino.esp8266.com/stable/package_esp8266com_index.json into Additional Boards Manager URLs field. You can add multiple URLs, separating them with commas.
Open Tools→Board:xxx→Boards Manager and install esp8266 by ESP8266 Community (and don't forget to select your ESP8266 board from Tools > Board menu after installation).
Or simply use luaLoader to run your favorite lua scripts. download here
Advanced users can load firmware's by nodemcu flash tool download it here
Simply NodeMCU custom builds on tha fly. get your's here
This are first prototype boards. (esp module and oled not included Use option to include) Delivery takes 2 weeks
Please check out my other products . Maybe there is something useful or of your interest. You will find amazing products of your interest. New cool products added every week. I have tindie and eBay stores below. Check both if you want. Make sure to open in new separator. Thanks for your time
Enter your email address if you'd like to be notified when ESP8266 OLED breakout board can be shipped to you:
$24.90
$40.95
$22.50
$29.80
$26.30
$19.90
$4.95
$23.00
$17.65
