DUAL PURPOSE 600 W module work as a step up boost DC DC converter or can be used as HI POWER LED driver Voltage & Current adj
This module is going to be definitely the swiss knife you need to supply many power hungry devices including Class D ampliers, HI POWER LED's or to be simply a laboratory/portable ajustable high powe…
Read More…This module is going to be definitely the swiss knife you need to supply many power hungry devices including Class D ampliers, HI POWER LED's or to be simply a laboratory/portable ajustable high power supply.
First it is simple, compact and robust with massive radiator attached. On board you have output/input screw connectors, a versatil DC jack , current / voltage adjustment screws. The current and voltage is adjustable, meaning that you can ajust the output voltage and/or set it to limit current at some point for circuit safety. Wide input 10-60V Wide output 12-80V Power rated 600W
This module can work as step-up DC/DC boost converter to get voltage between 12 and 80V from a lower input between 10 and 60V Example input 12V or 18V power supply or any low cost laptop power supply is able to drive this module.
You can also set limit current enabling this module to handle power LED 36V / 42V / 56V any voltage is possible, just limit the module current to HI POWER LED requirements for example 700mA, 1400mA, 3A ... Nice driver for 100W 200 W POWER LEDS
Can be used as laboratory power supply for many propouses thanks to wide output range. Use it also to power any laptop adjusting to correct voltage. From car battery or other power supply
Amazing piece of art!
*Tech details*
Please check also my other cool products on my store. New products every weeks. Welcome to my electronics world Visit my store here
Enter your email address if you'd like to be notified when POWER SUPPLY 10-60V to 12-80V or Power LED driver can be shipped to you:
$24.90
$40.95
$22.50
$29.80
$26.30
$19.90
$11.99
$29.80
$11.01
$19.90
