Wireless Transparent bidireccional serial uart LINK ( 18650 battery cell or up 5V supply) TX RX OTA over the air data HI POWER 20dBm
Sale is for TWO units pair bi-direccional transparent link high power modules Complete TRANSPARENT SERIAL "over air" link KIT. Those modules are a transparent serial UART wireless 2.4GHz link. Mean…
Read More…Sale is for TWO units pair bi-direccional transparent link high power modules
- Connect TX, RX & power and module is ready to play
The module can also be placed into a configuration (AT) mode and using simple ASCII 'AT' commands sent via its serial port its default parameters can be changed. This includes changing its frequency to one of 80 channels or its two byte ID which allows a theoretical 65536 modules to communicate with each other. - reception w automatic retry system is enabled (defaults to 100 retries) which will repeatedly resend a data packet a fixed number of times.
Specifications:
Connections:
VDD: 3.3V to 5V power supply
GND: Ground
TXD: serial port output, Arduino or USB to serial port RXD
RXD: serial port input, Arduino or USB to serial port TXD
CMD: Enter PIN AT mode, active low level;
GREAT APPLICATION example: COMMANDS OVER THE AIR to control any IO's, timmers, PWM analog from any arduino compactible board. Just create commands as you need and function handler, commands will be received by wireless and reach the target function or task
Send defined command by serial wireless and remote arduino/arduinos will do it. Create more functions for more commands or tasks. Check out: serial commands example
Download Arduno library here: AT command style library
Now you can control any arduino IO's wirelessly real time. Any microcontroller with TX, RX serial will work for this wireless modules.
See example serial commands over the air network diagram here: basic diagram multiple modules communication
Please check out my other products . Maybe there is something useful or of your interest. You will find amazing products of your interest. New cool products added every week. I have tindie and eBay stores below. Check both if you want. Make sure to open in new separator. Thanks for your time
Enter your email address if you'd like to be notified when Wireless Serial TRANSPARENT LINK data @ any place can be shipped to you:
Product: (4.00)
Documentation: (3.00)
Shipping: (4.00)
Communication: (4.00)
Fernando | June 30, 2016
$24.90
$22.50
$29.80
$26.30
$19.90
$14.20
$11.98
$24.90
