1/3-inch wide-VGA format CMOS active-pixel digital image sensor
Sold By Purple SquirrelThis product is no longer available for sale.
$5.95
Welcome to Purple Squirrel - The place to get electronic parts and kits for every skill level needed to make your electronics projects possible.
What is it? The MT9V034 is a monochromatic 1/3-inch wide-VGA format CMOS active-pixel digital image sensor with global shutter and high dynamic range (HDR) operation. With 6 micron sized pixels the a…
Read More…The MT9V034 is a monochromatic 1/3-inch wide-VGA format CMOS active-pixel digital image sensor with global shutter and high dynamic range (HDR) operation.
With 6 micron sized pixels the active imaging pixel array is 752 H x 480 V and is capable of 60 frames per second.
It is programmable via a two wire interface through a simple two-wire serial interface. The MT9V034 can be operated in its default mode or be programmed for frame size, exposure, gain setting, and other parameters. The default mode outputs a wide-VGA-size image at 60 frames per second (fps).
The complete part number for this device is: MT9V034C12STM-DP
Sugar Hill, GA, United States of America
