LiteFi 1 : Compact WiFi Router Tool for IoT & Low-Bandwidth Devices
Designed by Qortex in Spain
What is it? LiteFi 1 is an ESP8266-based NAT repeater built to help developers & makers quickly create low-bandwidth networks for WiFi devices such as IoT sensors and portable equipment. It was built…
Read More…LiteFi 1 is an ESP8266-based NAT repeater built to help developers & makers quickly create low-bandwidth networks for WiFi devices such as IoT sensors and portable equipment. It was built on martin-ger's open source Github project.
For advanced configuration (MQTT, Network Scan) you should interface using a serial monitor such as TeraTerm or Arduino's serial terminal.
For those who didn't know, this is the small & new version for the older Xtend Lite repeater, it arrives preloaded with the most up-to-date firmware version
Enter your email address if you'd like to be notified when LiteFi 1 | ESP8266 WiFi Repeater can be shipped to you:
1-19 | $18.00 |
20-99 | $15.00 |
100-499 | $12.00 |
500-999 | $10.00 |
1000+ | $8.50 |
$38.42 $45.20
$79.00
