Extend I2C communication for up to 100 meters, using a Single Wire. Supports multiple I2C devices of the same address.
What is it? This DS28E17 Breakout Board is a cutting-edge solution designed to significantly extend the capabilities of I2C communication. Traditionally, I2C communication is limited by distance and …
Read More…This DS28E17 Breakout Board is a cutting-edge solution designed to significantly extend the capabilities of I2C communication. Traditionally, I2C communication is limited by distance and can only be effectively used over short ranges. However, with the DS28E17 IC, this limitation is overcome, allowing for I2C communication to be extended for distances of up to 100 meters. This is a remarkable feat, especially considering that this extended range is achieved using just a single wire.
One of the standout features of the DS28E17 IC is its ability to support multiple I2C devices that have the same address. In standard I2C setups, each device on the bus must have a unique address to avoid conflicts and ensure proper communication. This can pose challenges, especially when integrating multiple devices from the same family or when device addresses are hard-coded and cannot be changed. The DS28E17 IC elegantly solves this problem by having a unique 64-bit ROM registration number that serves as a node address in the 1-Wire network.
Features
The breakout board has the following pinout:
You can use this board with open source Arduino libraries such as: DS28E17
Enter your email address if you'd like to be notified when 1-Wire To I2C Bridge DS28E17Q+ Breakout Board can be shipped to you:
$17.80
$105.80
$10.50
$5.20
