One pair of 6-pin Flat Flexible Cable Breakout Boards (1 Pair) + 20cm Flat Cable
What is it? This pair of breakout boards allow you to connect (6 pins) of different boards together in an elegant and clean manner, without the hassle and inflexibility of ribbon cables. The flat fle…
Read More…This pair of breakout boards allow you to connect (6 pins) of different boards together in an elegant and clean manner, without the hassle and inflexibility of ribbon cables. The flat flexible cable can be bent in any way you like without getting in the way.
I designed it with stress relief tabs cut out so you can loop the cable in a way that makes the cable inseparable from the connector even when pulled.
This pair of breakout boards comes with a 20cm flat flexible cable.
Enter your email address if you'd like to be notified when 6-pin Flat Flexible Cable Breakout Boards (1 Pair) can be shipped to you:
$1.80
