Allows you to connect a programmer to a bare Atmega168/328-AU TQFP-32 IC for programming before soldering
What is it? This programmer interface offers a TQFP32 socket that securely holds the microcontroller during the programming process. The socket is designed to ensure proper alignment and contact, min…
Read More…This programmer interface offers a TQFP32 socket that securely holds the microcontroller during the programming process. The socket is designed to ensure proper alignment and contact, minimizing the risk of errors or damage to the IC. Additionally, it provides a locking mechanism to securely hold the microcontroller in place.
Note: This is for the socket breakout board only and does not include the actual programmer (which you can easily use an Arduino for). See the following tutorial on how to use an Arduino for programming: https://www.instructables.com/Program-ATmega-328-Using-Arduino-Arduino-As-ISP/
The breakout board comes equipped with a 3.3V voltage regulator, an external crystal header (with 8MHz and 16MHz crystals included), and the required passive components. By connecting an Arduino-As-ISP through the SPI connections, you gain the ability to program the Atmega168/328 microcontroller before soldering it onto your PCB. This convenient feature eliminates the need for in-circuit programming, freeing up valuable space on your PCB.
Enter your email address if you'd like to be notified when Atmega168/328 TQFP32 Bare IC Programmer Interface can be shipped to you:
$17.80
