Integrates FDTI programmer with all pre-wired components for Bare ATmega328p Development Kit
What is it? Unlock the full potential of microcontroller development with the ATmega328p Development Bread(Dev)Board Kit. Designed for enthusiasts and professionals alike, this innovative setup integ…
Read More…Unlock the full potential of microcontroller development with the ATmega328p Development Bread(Dev)Board Kit. Designed for enthusiasts and professionals alike, this innovative setup integrates a fully functional FDTI programmer/sketch flasher with a bare ATmega328p Dual Inline (PDIP) IC onto a robust breadboard platform. This development kit is tailored for streamlined prototyping, ensuring you can move from concept to creation in record time.
We've noticed that most development boards need to be inserted into a platform like a breadboard. So we wondered, why not turn the breadboard itself into the development board?
Key Features:
Integrated FDTI Programmer: Directly program the ATmega328p IC without the need for additional hardware. The FDTI interface offers a seamless USB connection to your computer, enabling easy uploading of sketches and firmware directly from the Arduino IDE or other compatible software.
Pre-Flashed Arduino Bootloader: The ATmega328p IC comes with an Arduino bootloader already installed, enabling you to upload new sketches immediately via Serial using the integrated FDTI programmer. This feature eliminates the need for a separate programmer, streamlining your development process and making it more convenient. In Arduino IDE, simply select Arduino Duemilanove when uploading a sketch.
Pre-Assembled Essential Components: Comes equipped with all essential components including a 16 MHz crystal, 2 x 22pf capacitors for the crystal, and the ATmega328p microcontroller itself. These components are pre-wired and configured to meet the basic operational requirements of the microcontroller.
Ready-to-Use Setup: The breadboard layout is pre-wired for minimal configuration, allowing you to power up and start programming right out of the box. Ideal for rapid testing and iteration of designs without the hassle of complex setups.
Flexible Prototyping Space: Ample breadboard space adjacent to the microcontroller setup provides room for adding sensors, actuators, and additional circuitry. This space is perfect for expanding the capabilities of your projects or integrating specific functionalities required by your designs.
Potential Use Cases:
Educational Purposes: Ideal for students and educators looking to explore the fundamentals of microcontroller architecture, programming, and sensor integration. Provides a hands-on learning experience in embedded systems design.
DIY Projects and Robotics: Build and prototype custom robots or electronic gadgets. Whether it's automating your home or creating smart devices, the development kit offers the flexibility to bring your inventions to life.
Product Development & Testing: Startups and innovators can use the kit to prototype product concepts efficiently, testing functionalities and iterating designs without the need for complex and costly development tools.
Hobbyist Experiments: Perfect for hobbyists looking to delve into more advanced projects that require reliable and easy-to-use programming capabilities along with expandable options for various inputs and outputs.
Looking for a more permanent yet flexible prototyping platform? Check out our Snappable V-Grooved Protoboard (36 x 32 Positions)
Enter your email address if you'd like to be notified when ATmega328p Development Bread(Dev)Board Kit can be shipped to you:
$17.80
$17.95
$17.95
$15.88
