Effortlessly loosen new breadboard holes for easy component insertion with the durable and easy-to-use Breadboard Break-In Tool.
What is it? Introducing the Breadboard Break-In Punch Tool, your essential companion for making your new prototyping breadboards ready for seamless use. This innovative tool is designed to loosen the…
Read More…Introducing the Breadboard Break-In Punch Tool, your essential companion for making your new prototyping breadboards ready for seamless use. This innovative tool is designed to loosen the tight holes of a brand-new breadboard, ensuring that your components can be inserted into your breadboard with ease and precision, without the risk of damaging components.
To use, align the headers with the breadboard holes, push it in, and then wiggle it back out. Repeat if necessary.
Key Features:
Effortless Break-In: Equipped with male headers that fit perfectly into standard breadboard locations, this tool gently punches into the tight holes, making them more accommodating for your components.
Power Rail Compatibility: In addition to standard locations, the break-in tool is also designed to work with the power rails, ensuring every part of your breadboard is prepared for use.
Durable Design: Case is 3D printed and is built to withstand repeated use, making it a long-lasting addition to your prototyping toolkit.
Time-Saving: Eliminate the frustration and time spent forcing components into new breadboards. With this tool, you can quickly prepare your breadboard and get to work on your projects.
Easy to Use: Simply insert the tool into the holes of your breadboard, apply gentle pressure, and let the tool do the work of loosening the holes for you.
Ideal for hobbyists, engineers, and anyone who regularly works with breadboards, the Breadboard Break-In Punch Tool is a must-have for ensuring your prototyping experience is smooth and efficient from the start. Say goodbye to tight, stubborn breadboards and hello to effortless component insertion with this handy tool.
Note: If you regularly prototype using breadboards, check out our Breadboard Dual-Rail 3.3V+5V Power Supply & Board and Mini IO Breadboard-Friendly User Interface Module
Enter your email address if you'd like to be notified when Breadboard Break-In Punch Tool can be shipped to you:
