Versatile 3.3V/5V dual-rail power supply & board for breadboards with adjustable outputs, ideal for a range of electronics projects
What is it? Elevate your electronic projects to new heights with our cutting-edge Breadboard Dual-Rail 3.3V+5V Power Supply & Board, tailor-made for makers and hobbyists engaged in prototyping. This …
Read More…Elevate your electronic projects to new heights with our cutting-edge Breadboard Dual-Rail 3.3V+5V Power Supply & Board, tailor-made for makers and hobbyists engaged in prototyping. This compact and adaptable power module integrates effortlessly with standard breadboards, delivering stable and jumper-selectable voltage outputs of 3.3V and 5V to suit a broad array of components and circuits.
This product comes with a 24V / 2A power brick, providing a robust power supply. The breakout board adeptly reduces the 24V input to the commonly used voltages of 5V and 3.3V, perfect for a variety of electronic projects. Additionally, the 24V power supply can be utilized independently for projects requiring 24V. Thus, for an affordable price, you receive a versatile 3-in-1 power solution.
Key Features:
Dual-Rail Capability: Each power rail is independently adjustable via jumper settings, giving you the flexibility to set either rail to 3.3V or 5V based on your project needs.
High Efficiency Step-Down Conversion: Utilizes efficient DC-DC conversion technology to step down from a 24V 2A input to the desired voltage levels without significant power loss. It ensures clean and stable output, minimizing the risk of damaging sensitive electronic components.
Unique Form Factor: The breakout board module features a unique form factor that clamps onto the breadboard rails without occupying any breadboard space. It conveniently hangs off the end of the breadboard, keeping the workspace uncluttered.
Ease of Use: Simple plug-and-play design fits directly onto any standard breadboard, providing a hassle-free setup. Features clearly marked voltage selection switches for each rail, allowing easy adjustments on the fly without needing to reconnect components.
Potential Applications:
Looking for the perfect project for this power supply? Check out our ATmega328p Development Bread(Dev)Board Kit
Enter your email address if you'd like to be notified when Breadboard Dual-Rail 3.3V+5V Power Supply & Board can be shipped to you:
$2.50
$17.80
$13.80
$17.80
$17.90
$34.95
$2.75
