Cold Cathode Fluorescent Lamp + Inverter Board (Taken out from Fujitsu FI-6130 Scanners)
Sold By Questwise Ventures
What is it? This is a used Cold Cathode Fluorescent Lamp (26cm long) + Inverter Board (taken out from Fujitsu FI-6130 Scanner). The lamp lights up perfectly and has been tested working. What makes it…
Read More…This is a used Cold Cathode Fluorescent Lamp (26cm long) + Inverter Board (taken out from Fujitsu FI-6130 Scanner). The lamp lights up perfectly and has been tested working.
This lamp is perfect for upcycling DIY projects. It glows beautifully and you can use it to add flare to any projects in mind.
To use it, you will need an additional 24V DC power supply that can output at least 2.5A. Just feed the power through the power connector pins on the inverter board and see the lamp glow!
The inverter board itself measures 4.8cm x 4.2cm.
Enter your email address if you'd like to be notified when Cold Cathode Fluorescent Lamp + Inverter Board can be shipped to you:
$1.85
$255.00
$1.85
$1.00
