Brighten projects with a 30cm Amber LED strip, perfect for Raspberry Pi/Arduino cases & custom signs
What is it? Introducing the latest iteration of the 30cm Flexible LED Neon-Like Glow Strip (Amber). This NEW version includes an LED strip with both terminals conveniently located on one end! This de…
Read More…Introducing the latest iteration of the 30cm Flexible LED Neon-Like Glow Strip (Amber).
This NEW version includes an LED strip with both terminals conveniently located on one end! This design offers greater versatility, eliminating the need to connect wires at the other end. The strip is pre-soldered to a compact breakout board featuring hybrid castellated pin headers. You can either solder it directly to your custom PCB design for a sleek, pin-free connection, or use standard 100 mil (2.54 mm) pitch headers for added flexibility.
Illuminate your projects with this 30cm (amber) LED glow strip, designed to emulate the radiant intensity of neon lights. They consist of numerous micro LED diodes fused onto an extremely flexible metal backing, subsequently encased in silicone for added safety and flexibility. This strip not only ensures consistent luminosity but also offers a vibrant and uniform glow that can transform any project. The glow is so bright that it looks like a neon strip. This LED strip is perfect for decoration Raspberry Pi and Arduino cases, or making custom signs or mood lights.
The tiny breakout board is easy to use and has the following pinouts:
To use it, connect it with 3.3V VIN preferably through a current limiting resistor and see the gorgeous glow right in front of your eyes.
Here are some unique use cases for the 30cm Flexible LED Neon-Like Glow Strip (Amber):
Custom Electronics Enclosures: Use the LED strip to outline or accentuate the edges of custom electronics enclosures, such as Raspberry Pi or Arduino cases, adding a vibrant, professional-looking glow to your project.
Wearable Tech Projects: Incorporate the flexible LED strip into wearable technology, like custom costumes or accessories, to create striking, neon-like lighting effects that stand out in low-light environments.
Architectural Models: Add a realistic glow to architectural models by embedding the LED strip into pathways, building edges, or landscaping features, creating an eye-catching display that simulates neon lighting.
Interactive Art Installations: Utilize the LED strip in interactive art pieces where responsive lighting can enhance the viewer's experience. The flexible design allows for creative placement and integration into various materials.
Vehicle Interior Lighting: Enhance the interior of cars, motorcycles, or bicycles with custom accent lighting, adding a modern, sleek look with the neon-like glow. The flexibility of the strip makes it easy to fit into tight spaces or along curved surfaces.
Desk or Room Accents: Use the strip to outline desks, shelves, or other furniture in a workspace or living area, creating a stylish ambiance with its vibrant amber glow. The flexibility of the strip allows for easy application in various shapes and designs.
Custom Signage: Design custom signs for personal or business use, utilizing the uniform glow to create professional-looking neon-like text or symbols. The flexibility allows for intricate designs that would be difficult with traditional neon lighting.
NOTE: If instead you are looking for a flat flexible white glow, check out our FlexiGlow: Flat Flexible LED White Backlight Panel
Enter your email address if you'd like to be notified when Flexible 30cm LED Neon-Like Glow Strip (Amber) V2 can be shipped to you:
$9.88
$1.05
$9.88
$9.88
