23 x 30 positions (6cm x 8cm) flexible protoboard: Bendable, durable design for compact circuits. Ideal for wearables & tight spaces.
Sold By Questwise Ventures
What is it? The 6cm x 8cm flexible bendable protoboard is a versatile and innovative solution for electronics enthusiasts and professionals alike. Unlike traditional rigid protoboards, this board off…
Read More…The 6cm x 8cm flexible bendable protoboard is a versatile and innovative solution for electronics enthusiasts and professionals alike. Unlike traditional rigid protoboards, this board offers the flexibility to bend, allowing for unique and compact circuit designs that can potentially wrap around objects. Despite its flexibility, the board is designed to withstand repeated bending, ensuring longevity and reliability in your projects. This protoboards has 23 x 30 positions.
These holes are arranged in a standardized 100 mil (2.54mm) grid pattern, allowing for easy insertion of electronic components such as resistors, capacitors, integrated circuits (ICs), and wires. Please note that these protoboards do not have pre-existing traces connecting the holes on the PCB. To establish connections, it is common practice to bend the leads of through-hole components and insert them into the respective holes.
Some potential applications:
Enter your email address if you'd like to be notified when Flexible / Bendable 6cm x 8cm Protoboard can be shipped to you:
$17.80
$22.50
$749.00
$97.99
$24.95
