Versatile, ultra-thin LED backlight (29x36x0.85mm) for makers, perfect for wearable tech, DIY gadgets, art, home automation, and more.
What is it? Introducing FlexiGlow, the innovative and versatile LED backlight panel that brings your creative visions to life. Measuring just 29mm by 36mm x 0.85mm, this ultra-thin and flexible backl…
Read More…Introducing FlexiGlow, the innovative and versatile LED backlight panel that brings your creative visions to life. Measuring just 29mm by 36mm x 0.85mm, this ultra-thin and flexible backlight is perfect for makers, hobbyists, and professionals alike. Whether you're into wearable tech, DIY gadgets, art projects, home automation, prototyping, educational kits, vehicle modifications, or photography and videography, FlexiGlow has you covered.
Key Features:
Ultra-Thin and Flexible: At just 29mm by 36mm x 0.85mm, FlexiGlow fits seamlessly into any project, no matter how tight the space.
Bright and Even Lighting: Provides consistent, even white light to enhance visibility and aesthetics.
Easy to Integrate: Simple to incorporate into a wide variety of projects with minimal setup, FlexiGlow comes with a pre-soldered tiny breakout board that features hybrid (header/castellated pads) for easy connection. Just connect VIN (around 3V) and GND, and it will emit an evenly distributed bright white light. You can also use PWM on the VIN pin to adjust the brightness of the glow.
Potential Use Cases:
Backlight For Smartwatch Displays: The FlexiGlow Flat Flexible LED White Backlight Panel is the perfect solution for enhancing smartwatch displays, providing bright and evenly distributed white light to ensure readability in various lighting conditions.
Wearable Tech: Add a futuristic touch to jackets, shirts, and accessories with built-in lighting. Create illuminated name badges or event passes for a unique, eye-catching look. Perfect for cosplay or theater costumes, adding dramatic lighting effects.
Portable Lighting: Ideal for building compact, portable light sources for reading or photography.
Light Art: Enhance sculptures or installations with flexible lighting for stunning visual effects.
Indicator Lights: Perfect for projects requiring flexible indicator lights.
Bike Safety: Enhance visibility and safety by adding to bikes.
Car Modding: Customize car or motorcycle lighting for a unique look.
Mini Light Panels: Create small, portable light panels for photographers and videographers, perfect for on-the-go lighting needs.
Enter your email address if you'd like to be notified when FlexiGlow: Flat Flexible LED White Backlight Panel can be shipped to you:
$17.80
$79.00
$27.72
$26.65
$26.65
