Single Flute 1.5mm Corn Endmill for High Precision CNC milling of Wood, Plastic and more
Sold By Questwise Ventures
What is it? Single Flute 1.5mm Corn CNC Endmill The 1.5mm cutting diameter of this endmill is ideal for cutting small features and intricate shapes, making it a popular choice for high-precision mill…
Read More…Single Flute 1.5mm Corn CNC Endmill
The 1.5mm cutting diameter of this endmill is ideal for cutting small features and intricate shapes, making it a popular choice for high-precision milling applications. The endmill can be used to cut a variety of materials, including wood, plastics, and composites, with exceptional accuracy and surface finish.
This endmill design is optimized for efficient chip evacuation, which helps prevent the buildup of chips and debris that can interfere with the cutting process. The single flute design also helps to reduce the amount of cutting forces required, which allows for faster cutting speeds and longer tool life.
Specifications:
Enter your email address if you'd like to be notified when High Precision Single Flute 1.5mm CNC Corn Endmill can be shipped to you:
$870.00
$640.01
$489.99
$649.99
