Seamless magnetic snap-on design for effortless connections. Breaks out VIN, D+, D, GND of USB 2.0. See demo for effortless connectivity.
What is it? Introducing our Magnetic USB 2.0 Cable & Connector Breakout Board, a revolutionary solution for seamless and secure USB connections. This innovative product combines the convenience of a …
Read More…Introducing our Magnetic USB 2.0 Cable & Connector Breakout Board, a revolutionary solution for seamless and secure USB connections. This innovative product combines the convenience of a magnetic connector with the versatility of a standard USB 2.0 breakout board, offering users a reliable and efficient way to connect their devices.
See demo video below. In the video, the magnetic breakout board is connected to an endoscope camera. Upon snapping onto the USB cable end, the video feed promptly displays on the laptop monitor, showcasing the effortless connectivity and functionality of the product.
Key Features:
Magnetic Connector: The magnetic connector ensures effortless and secure connection between the USB cable and the breakout board. As soon as the user brings the two ends of the magnetic connectors together, they automatically snap together magnetically, eliminating the need for precise alignment and reducing wear and tear on the connectors.
Ring Connector Design: The breakout board is designed with a magnetic ring of pins. This allows the user to snap on the cable in any rotation without specific alignment of pins.
Standard USB 2.0 Breakout Board: The breakout board outputs the standard USB 2.0 pins, including VIN, D+, D-, and GND, providing compatibility with a wide range of devices and applications. Whether you're prototyping a new project or connecting peripherals to your computer, this breakout board delivers reliable performance.
Versatile Length: With a generous 1-meter length, our USB cable offers ample reach for diverse applications, ensuring flexibility and convenience for users across various scenarios.
LED Indicator: The USB cable features a vibrant blue LED ring around the end, providing visual confirmation of the cable being plugged in. The LED adds a touch of style to the cable while also serving as a convenient indicator for users.
Potential Use Cases:
Prototyping and Development: Engineers and hobbyists can use the Magnetic USB Cable & Connector Breakout Board for prototyping and development projects. The magnetic connector simplifies the process of connecting and disconnecting devices, making it easier to iterate on designs and test different configurations.
Mobile Devices: In applications where frequent connection and disconnection are common, such as charging or data transfer for mobile devices, the magnetic connector offers added convenience and durability. Users can effortlessly connect their smartphones, tablets, or other mobile devices without worrying about damaging the ports.
Industrial Environments: In industrial settings where dust, debris, or moisture may be present, traditional USB connections can be prone to damage or failure. The magnetic connector provides a sealed, secure connection that helps protect against environmental hazards, ensuring reliable operation in demanding conditions.
Automotive Applications: Automotive applications often require robust and reliable connectivity solutions. The Magnetic USB Cable & Connector Breakout Board can be used for connecting devices within vehicles, such as dash cams, GPS units, or diagnostic tools, providing a secure and hassle-free connection that withstands vibrations and movement.
Audio/Visual Equipment: From professional audio interfaces to home entertainment systems, the Magnetic USB Cable & Connector Breakout Board offers a convenient solution for connecting audio and visual equipment. The magnetic connector allows for quick and easy connections, reducing setup time and minimizing the risk of accidental disconnection during use.
The Magnetic USB Cable & Connector Breakout Board combines the convenience of a magnetic connector with the versatility of a standard USB 2.0 breakout board, making it an ideal choice for a wide range of applications. For example, powering this Canon in D Chorus: Mechanical Music Box Breakout
Enter your email address if you'd like to be notified when Magnetic USB 2.0 Cable & Connector Breakout Board can be shipped to you:
$17.80
$4.49
$1.99
