This Inductorless Piezo Buzzer Amplifier Board increases the volume of buzzers and can drive outputs up to 18Vpp from a 3V Supply.
What is it? This breakout board can drive piezo outputs up to 18Vpp from 3V supply. An internal 3X charge pump generates boosted supply voltage for piezo driver. Since this does not rely on inductors…
Read More…This breakout board can drive piezo outputs up to 18Vpp from 3V supply. An internal 3X charge pump generates boosted supply voltage for piezo driver. Since this does not rely on inductors, it will keep the design small and flat.
To use it, just make the following connections:
I was searching online on how to increase the volume of piezo buzzers and did not find an easy solution in the form of a breakout board, and so I made this.
It comes in a small form factor and can be easily integrated to give your projects a much louder voice.
Enter your email address if you'd like to be notified when MAS6240C Piezo Buzzer Amplifier Breakout Board can be shipped to you:
$24.99
$110.00
