The Micro USB Power-Only Breakout Board is a compact, efficient, and
What is it? The Micro USB Power-Only Breakout Board is a compact, efficient, and straightforward solution for projects requiring USB power delivery without the need for data lines. Featuring only the…
Read More…The Micro USB Power-Only Breakout Board is a compact, efficient, and straightforward solution for projects requiring USB power delivery without the need for data lines. Featuring only the +5V (VBUS) and Ground (GND) connections, this breakout board is perfect for powering your electronics while keeping your design streamlined and free from unnecessary complexities. Its minimalist design ensures maximum ease of use, making it an ideal choice for DIY enthusiasts, prototyping, and custom electronics projects.
Features
No USB Data Line Interference: USB data lines can generate high-frequency signals, which may induce noise in sensitive analog circuits or low-power RF systems. By excluding data lines, the breakout board eliminates this potential interference.
Preventing Misuse in Public or Shared Spaces: When used in public USB charging stations or shared power sources, a power-only board can prevent potential misuse, such as unauthorized data access or malware installation on connected devices.
Cleaner Power Supply: A focus on power delivery allows for optimized power trace design and potentially larger pads or better connections for robust current handling.
Enter your email address if you'd like to be notified when Micro USB Power-Only Breakout Board can be shipped to you:
$13.80
$13.50 $15.00
$72.00
