Compact UI & Sleek Control Knob for Intuitive Menu Navigation and Instant Action Confirmation
What is it? Introducing the latest iteration of the Mini Rotary Encoder w/ Push Button Breakout Board This NEW version features hybrid castellated pin headers, allowing you to either solder it direct…
Read More…Introducing the latest iteration of the Mini Rotary Encoder w/ Push Button Breakout Board
This NEW version features hybrid castellated pin headers, allowing you to either solder it directly to your custom PCB design without bulky header pins or use standard 100 mil (2.54 mm) pitch headers for added flexibility.
This Mini Rotary Encoder Push Button & Castellated Pins is a versatile and compact electronic module designed to provide precise and reliable rotational input and push-button functionality for a wide range of applications. This breakout board combines the convenience of a rotary encoder and a momentary push button in a single integrated solution, making it an ideal choice for various interactive projects.
The rotary encoder of this breakout board allows for accurate and incremental rotational input. It features a durable and smooth rotary shaft that can be easily turned in either clockwise or counterclockwise directions, providing a tactile and responsive user experience.
The integrated momentary push button adds an additional input functionality, enabling users to execute specific actions or trigger events with a simple press. This button is designed to be highly reliable and responsive, ensuring seamless interaction in diverse applications such as menu selection, mode switching, confirming choices, or triggering specific actions.
Whether you are building a user interface for a digital device, designing a control panel for a machine, or creating an interactive installation, the Rotary Encoder with Momentary Push Button Breakout Board provides a reliable and efficient solution for capturing precise rotational input and integrating push-button interactions.
This Rotary Encoder breakout board has 4 inputs:
You can connect A, B and BTN to any digital input pins of a microcontroller and use open source libraries such as: Rotary Encoder Arduino Library
Here are some unique and interesting use cases for this Mini Rotary Encoder Push Button & Castellated Pins:
Custom Audio Mixers: Integrate the rotary encoder into a custom-built audio mixer to adjust volume levels, pan audio channels, or tweak EQ settings. The push button could switch between different control modes or mute/unmute channels.
Home Automation Control Knob: Use the encoder as a central control knob for a smart home setup. The rotation could adjust lighting brightness, temperature settings, or volume of a connected sound system. The push button could be used to switch between different devices or scenes.
3D Printer Control Interface: Incorporate the breakout board into the control interface of a 3D printer. Allow users to fine-tune printing parameters like speed, temperature, or layer height in real-time. The push button could pause/resume printing or confirm settings.
Custom Retro Game Controller: Design a retro-style game controller where the rotary encoder is used for navigating menus or adjusting in-game parameters, and the push button serves as a select or action button. To make the retro-style theme more interesting, you can pair this rotary encoder with our Audio Feedback Module for UI Buttons for a complete retro experience.
Camera Focus and Zoom Control: Integrate the encoder into a custom camera rig where rotation controls the focus or zoom of a camera lens, and the push button toggles between modes (e.g., focus to zoom or aperture settings).
Advanced Robotics Control Panel: Use the encoder in a robotics control panel to precisely control motor speeds, arm positions, or tool functions. The push button could activate specific robot functions or emergency stops.
Note: Looking to pair this cute Rotary Encoder with a miniature OLED screen, check out our Miniature 0.32" OLED Screen + Rotary Encoder Combo
Enter your email address if you'd like to be notified when Mini Rotary Encoder Push Button & Castellated Pins can be shipped to you:
$17.80
$7.80
$13.80
$8.80
