36 x 32 Positions Snappable Protoboard simplifies the process of obtaining the perfect prototyping area for your project
What is it? Introducing the Snappable V-Grooved Protoboard, a versatile solution for your prototyping needs. Whether you desire a long and slender board, a compact size, or an abundance of holes, thi…
Read More…Introducing the Snappable V-Grooved Protoboard, a versatile solution for your prototyping needs. Whether you desire a long and slender board, a compact size, or an abundance of holes, this protoboard has you covered. It features a large protoboard with v-scored lines (spaced each 4 x 4 holes apart), allowing you to effortlessly customize the length and width of your protoboard by snapping off sections. Each position hole is through-hole plated on front and back. These holes are arranged in a standardized 100 mil (2.54mm) grid pattern, allowing for easy insertion of electronic components such as resistors, capacitors, integrated circuits (ICs), and wires. Please note that these protoboards do not have pre-existing traces connecting the holes on the PCB. To establish connections, it is common practice to bend the leads of through-hole components and insert them into the respective holes.
The Snappable Protoboard simplifies the process of obtaining the perfect prototyping area for your project. With its straightforward design, you can easily create the ideal size required. One of the main advantages of a protoboard is its reusability. Connections can be quickly modified by rearranging wires or components. This flexibility makes it an ideal tool for experimentation, rapid prototyping, and educational purposes.
Enter your email address if you'd like to be notified when Snappable V-Grooved Protoboard (36 x 32 Positions) can be shipped to you:
$12.80
$24.80
$2.50
$17.80
$13.80
$17.80
