Affordable Solenoid Lock Board for Physical Security: Easy setup with 3 connections, versatile for cabinets, offices, and retail
What is it? Introducing the Solenoid Door/Cabinet Lock Assembly Breakout Board - an affordable solution for getting your hands on some physical security. This user-friendly breakout board simplifies …
Read More…Introducing the Solenoid Door/Cabinet Lock Assembly Breakout Board - an affordable solution for getting your hands on some physical security. This user-friendly breakout board simplifies your setup, needing just three connections:
Out of the box, the lock latch is securely in the "locked" position. By applying a HIGH signal to the RLS pin, the latch will retract slightly, enabling the lock to open effortlessly. See demo video below. While the lock mechanism isn't constructed from metal, it is injection-molded from durable ABS plastic, making it versatile and suitable for a wide range of applications.
Potential Use Cases
Secure Cabinets and Drawers:
Office Access Control:
Retail Displays:
Want to add RFID functionality to this Solenoid Lock? Check out our RFID PN532 NFC Breakout Board + Wearable Ring Tag
Enter your email address if you'd like to be notified when Solenoid Door / Cabinet Lock Assembly Breakout can be shipped to you:
$13.85
$13.80
$13.85
$29.95
$17.65
$10.80
