power supply for mixing desk +/- 17 Volts (adjustable) at 4 Amps, 48 Volts at 1 Amp
Designed by Australian Technical Production Services in Australia
This power supply may be used to replace a faulty supply in an existing desk or as a replacement for an external supply. The power supply is bigger then the other one I have listed and can deliver +/…
Read More…This power supply may be used to replace a faulty supply in an existing desk or as a replacement for an external supply. The power supply is bigger then the other one I have listed and can deliver +/- 17 Volts (trimmable between 12 and 17V) at 4 Amps and +48 Volts at 1 Amp
NOTE This is a Short form kit (PCB and Instructions only) for a mixing desk power supply.
As the power supply uses switching regulators, it only requires a readily available dual 25V 300VA transformer. Also by using switch mode circuitry, keeps power dissipation low, and efficiency high
Enter your email address if you'd like to be notified when Bigger mixer power supply 4 Amps can be shipped to you:
Hornsby, New South Wales, Australia
Ships from Australia.
1 Review | 37 Orders
