Linear power supply for mixing desk, microphone pre-amps or other projects
Designed by Australian Technical Production Services in Australia
This is a power supply designed as a replacement for the Soundcraft CPS 150 (which is no longer available) but it can be used for many other applications as well. This power supply will deliver +/- 1…
Read More…This is a power supply designed as a replacement for the Soundcraft CPS 150 (which is no longer available) but it can be used for many other applications as well.
This power supply will deliver +/- 17V at 1.5 Amps (although this can be varied), 48V at up to 1/2 an amp and also has room for another positive regulator to provide a 12V lamp supply, although this can be fitted with a 7805 instead for a lower current 5 V supply.
It uses a voltage multiplier to generate the 48V supply so can use readily available power Transformers with either dual 16-18V windings or centre tapped 32-36V windings.
At the moment the kit consists of PCB and instructions only
Enter your email address if you'd like to be notified when PCB for Mixing desk PSU, equivalent to CPS150 can be shipped to you:
Peter | Aug. 2, 2017
Hornsby, New South Wales, Australia
Ships from Australia.
1 Review | 37 Orders
$8.90
$27.00
