Low cost practical USB development board.
Designed by Rabid's Electronics Emporium in United KingdomThis seller is taking a break. Sign up below to get an email when they're back!
What is CHUSBIE? CHUSBIE is a range of development boards for the CH55x range for Microcontrollers from WCH, which keeps low cost and usability as its guiding principles. What is the CHUSBIE552? CHU…
Read More…What is CHUSBIE?
CHUSBIE552 is the development board specifically for CH552T or the CH552G MCUs. Both versions are available as the CHUSBIE552(T) and the CHUSBIE552(G). This listing is for the CHUSBIE552(T)
Why Am I making it?
I feel that adding USB interfaces to devices should not be hard or costly. USB has been around for many years now but there still seems to be a barrier to entry in terms of cost or complexity. The CHUSBIE552 is both compact and low cost which gives the ability to permanently embed it into a project. I have tried to include items that I feel help keep the (TTB) Time To Blink low.
What makes it special?
After experimenting with this MCU on protoboards I decided I wanted to see the CH552T shipped together in a feature set to help me with my own developments.
So I have loaded the board with the following feature set:
CH552T Specs
Contents
Other info
CHUSBIE is an OpenSource Hardware project with design file and BOMs freely available via the links below. Release with Solder PAD V2.1 permissive license.
Enter your email address if you'd like to be notified when CHUSBIE552(T) USB Development Board can be shipped to you:
Sheffield, Sheffield, United Kingdom
Ships from United Kingdom.
$17.99
$24.99
$4.70
