expansion board for clockworkpi uConsole
Designed by Joe in Bulgaria
USB hub to expose internal, non populated usb ports and multiply them to 3 external and 2 internal. 3 external and soldering pads are connected to USB2.0 hub, internal USB is connected directly to CM…
Read More…USB hub to expose internal, non populated usb ports and multiply them to 3 external and 2 internal. 3 external and soldering pads are connected to USB2.0 hub, internal USB is connected directly to CM module USB and can be used to add some internal board to uConsole. Soldering pads to attach some usb board anywhere in the chassis and connect it with wires.
Enter your email address if you'd like to be notified when uCon USB ext. board can be shipped to you:
