This seller is taking a break until July 24, 2025. Sign up below to get an email when they're back!
USB hub to expose internal, non populated usb ports and extend them with 3 external and 2 internal. 3 external and soldering pads are connected to USB2.0 hub, internal USB is connected directly to CM…
Read More…USB hub to expose internal, non populated usb ports and extend them with 3 external and 2 internal. 3 external and soldering pads are connected to USB2.0 hub, internal USB is connected directly to CM module USB and can be used to add some internal usb c board to uConsole. Soldering pads to attach some usb board anywhere in the chassis and connect it with wires. All C ports are set to output 0.5A. ROHS solder and 1 micron EING Surface Finish. Length matched USB data lines with ESD protection. Serialised boards with some via art.
clockworkpi, uConsole, usb hub, CM4, CM5
Enter your email address if you'd like to be notified when uConsole USB ext. board can be shipped to you:
Samuel | June 9, 2025
Maksym | May 30, 2025
Ryoji | April 6, 2025
Tony | April 4, 2025
Ben | March 14, 2025
Oleksii | March 8, 2025
