USBC2I2C allows direct communication between a computer (over serial COM Port) and a device with an I2C interface over USBC
Designed by Restoration Hub in Canada
What is it? It is a small piece of hardware, printed circuit board (PCB) with USB and 4 pin JST 1.0 connector that works as a buffer between the connected devices with an I2C interface and a PC. The …
Read More…It is a small piece of hardware, printed circuit board (PCB) with USB and 4 pin JST 1.0 connector that works as a buffer between the connected devices with an I2C interface and a PC. The device is mounted as Serial COM Port.
In electronics, to provide a certain functionality, there is always a need to communicate to any sort of a device such as a sensor, screen, touch screen, IO device, ADC/DAC, memories of any types or else. Many of these devices are accessible through an I2C interface. Usually, the buffer between these devices and a computer is an Arduino or any other embedded platform. So there is a continuous need to develop these platforms. USBC2I2C allows to skip this step by allowing a simple and direct communication through serial terminal interface to any mounted to it I2C device.
It has unique set of features which is hard to find in one device 1) COM to I2C built in parser 2) USBC with 10W power delivery 3) No drivers needed 4) Updatable via DFU (No programmer needed) 5) Small form factor
Enter your email address if you'd like to be notified when Serial COM To I2C Over USBC Interface - USBC2I2C can be shipped to you:
