AC Dimmer Board that is controlled by a PWM signal or a 0V to 2.65V signal (microcontroller, potetiometer or any arduino)
Designed by RF Simplicity in CanadaThis product is no longer available for sale.
Features: Dimmer Board for selecting any voltage between 0 VAC - 120 VAC or 0 VAC - 240 VAC Zero-Cross detection Programmable Atmel ATtiny85 via 6-pin ICSP header Compatible with any Arduino! Can …
Read More…Features:
NEW Triac rated for:
Controls the amount of dimming based on input voltage on the CTRL pin or a PWM signal on the pin between '+' and '-' You can select the input mode (CTRL voltage input or PWM signal input) by making the Mode Pin (under '+') LOW or HIGH, respectively.
Voltage Mode:
Voltage Amount of Dimming
0 - 0.65V: 100% Dim (Fully OFF)
0.65V - 2.65V: 100% - 0% Dim (Based on 'CTRL' Voltage)
2.65V - 5V: 0% Dim (Fully ON)
Note: In voltage mode for Normally OFF some applications require a resistor (tested with 65K) between CTRL and Ground, while directly powering from an Arduino does not.
PWM Mode:
Duty Cycle Amount of Dimming Arduino Code
0 - 5% 100% Dim (Fully OFF) analogWrite(0) to analogWrite(15)
5%-40%: 100% - 0% Dim analogWrite(15) to analogWrite(90)
(^^Based on 'PWM' Duty Cycle^^)
Greater than 40%: 0% Dim (Fully ON) analogWrite(90) to analogWrite(255)
5V connects to '+' pin on the ICSP header (marked on PCB) Ground connects to '-' on the ICSP header (marked on PCB)
Example uses: Control the speed of a fan, drill, motor, etc. Dim lights. Control temperature using a heater. Chicken coops, brewing beer, maintaining a set-point using Alernating Current, etc.
While high voltage systems are interesting experimentally, they can be dangerous, and if not treated with care, respect and intelligence, they can result in a fatal injury.
I will program for 60Hz if ordered in North America. For all other continents I will program for 50Hz unless you specify otherwise. (It can, however, be reprogrammed)
