Double-digit full color RGB LED timer and counts down until the green or red light comes on.
Designed by Rousis Systems LTD in Bulgaria
What is it? RGB LED timer for traffic lights with diameter 20 cm. Is designed and produced entirely by our company. Actually it is a double-digit full color RGB LED timer and counts down until the gr…
Read More…RGB LED timer for traffic lights with diameter 20 cm. Is designed and produced entirely by our company. Actually it is a double-digit full color RGB LED timer and counts down until the green or red light comes on. The processor of the countdown display provides a system for automatic learning of the time that each lamp lasts, with the help of two high voltage monitoring inputs. The board can be easily installed and operate in any traffic light housing of diameter 20 cm, as it is powered directly by 220 Volts AC. The device has an RS485 Modbus interface for connection to PLC or other control systems. It also has a photo sensor for automatic adjustment of brightness depending on the external lighting conditions.
Designed to operate on traffic lights automation for timing the signage /
Enter your email address if you'd like to be notified when Traffic Lights RGB LED Countdown Timer 20cm can be shipped to you:
$26.65
$26.65
$7.80
$34.19 $35.99
