Protect your code from unauthorized copying with hardware-based solution. Define your encryption key and integrate it with your application.
Designed by SpinAndTurn Store in PortugalThis product is no longer available for sale.
$297.00
$5.69
$11.99
What is it? Driverless hardware-based protection uses a physical device, commonly known as piggy-back internally attach to GPIO Raspberry Pi. Rapid & simple implementation, by compiling your code…
Read More…Driverless hardware-based protection uses a physical device, commonly known as piggy-back internally attach to GPIO Raspberry Pi. Rapid & simple implementation, by compiling your code with available library you can use the unique hardware serial number to verify
Hardware internal authentication discourages hardware cloning. Protect multiple applications with one device.
Easy plug & play for Linux code protection.
Step-by-step
1-9 | $9.50 |
10+ | $9.00 |
$699.00
$27.00
