Adapter Board, which connects an Arduino Nano with a CC1101 433/868Mhz radio module, commonly used in home automation projects using FHEM.
Designed by Sascha's DIY Electronics in Germany
This is an Adapter PCB to add a CC1101 868/433Mhz radio module to your home automation system. It connects a 4-channel level shifter module, a CC1101 radio module and an Arduino Nano on the back. Yo…
Read More…This is an Adapter PCB to add a CC1101 868/433Mhz radio module to your home automation system. It connects a 4-channel level shifter module, a CC1101 radio module and an Arduino Nano on the back.
You get: - Adapter PCB
For the PCB to work, you will need the following components:
Enter your email address if you'd like to be notified when nanoCUL Adapter Board for CC1101 433/868Mhz CUL can be shipped to you:
$1.00
$1.30
$2.50
$1.30
