The Remote Differential Receiver Board is a four port receiver that works with the PB16v2, Kulp, or Falcon controllers in Normal Mode.
Designed by scooter_seh in United States of AmericaThis seller is taking a break. Sign up below to get an email when they're back!
What is it? The Remote Differential Receiver Board is a four port receiver that works with the PB16v2, Kulp, or Falcon controllers in Normal Mode. The Remote Differential Receiver can be placed over …
Read More…The Remote Differential Receiver Board is a four port receiver that works with the PB16v2, Kulp, or Falcon controllers in Normal Mode. The Remote Differential Receiver can be placed over 200 feet from the main controller and connected with a CAT5 cable. Can be used to run pixels at a different voltage without modifying your main controller setup. 5v or 12v+ power input must be configured before power up. Configuration is fully supported in xLights.
Enter your email address if you'd like to be notified when Remote Differential Receiver Board can be shipped to you:
$105.00
$89.95
$35.99
$500.00
