Looko2® Smart Internet Air Pollution Laser Sensor For Your Home
Designed by Sensors in Poland
Looko2® Smart Internet Air Pollution Sensor For Your Home Looko2® is WiFi enabled, simple and affordable sensor that measures PM1, PM2.5 and PM10 pollution level around your Home or any other place …
Read More…Looko2® is WiFi enabled, simple and affordable sensor that measures PM1, PM2.5 and PM10 pollution level around your Home or any other place where you install it. It can inform you about degraded air quality outside with its bright LEDs installed in nice case.
Connect Looko2® to your home WiFi and get live readout of air quality. Look at the sensor and see the color that it is showing. Red – stay at home, Yellow – consider twice, Green or Blue – time for outside trip or training. With singe device your kids, parents and even neighbor can understand when it is safe to step outside.
Worried about SMOG (smoke+fog)? Living in big city and unsure about air quality? Want to measure air pollution level exactly where you live and play? Need some reports and statistics for your data analysis on air quality? Quick info about pollution outside your Home ‘right here right now’? Looko2® automatically checks level of particles that have diameter less than 1, 2.5 and 10 micrometers for you every minute.
· Continuous laser measurement of air quality
· Immediate information with bright LEDs, WWW Live Data, mobile apps
· Open API for Home Automation Systems and your own solutions
· Easy to adopt to your website
Want to see a bigger picture? Interested in what is the air quality in other parts of your city? Are you sure your kid is having fun in kindergarten’s playground when it’s safe? Trying to plan your running schedule but not sure what is the best time?
· Share your measurements with others on our Live Map
· See other Looko2® sensors and check differences between various regions of your city
· Install another sensor next to your kid’s school or kindergarten
· Download daily reports and discuss results with your friends
Connect Looko2® to power supply
Find Looko2® wifi network
Configure to connect to your home network, provide name to your sensor, fill in GPS coordinates to show up on Live Map properly
Save settings – Looko2® will reboot and start measuring Air Quality with minutes.
Need to move to another place? No worries. Move within current WiFi range or reset it with single click and configure again. Easy configuration menu with step by step manual available on looko2.com
Constant Laser Air Quality Check
With built in laser sensor Looko2® automatically pulls air sample, analyses it and sends data to our servers. You can see every minute data, hourly averages and more using non changeable link to your sensor’s readouts. Easy to share with friends and post on social media.
Resistant for outside weather
Place wherever you like. Looko2® is prepared to be working outside (or inside if you need it) and tested by our users in various temperatures. From chilling mountain’s cold through beautiful Philippines to Texas valleys and more!
Multiple Looko2® sensors on one map – even more detailed view
Live Map, detailed reports, API and quick access to data allows you to compare various sensors readouts. Install more than one, share on various websites, use available widgets or create your own. With multiple Looko2® you can easily assess what is the best path and timing for you next training outside.
Open Especially for you
Looko2® comes with already build in rich solutions. It is up to you what to do with it.
Rich Free API to build apps, pull data and generate your own data driven reports
Smart Home plugins – ready for Fibaro, Home Assistant, Domoticz and much more
Various mobile apps (currently available in PL only but we are working on it..) for easy and remote app access to your data
Powered by multiple servers locates across the World – for quick and reliable response and data storage
Reports available all the time – we do not delete old reports. You can go back in time and find data from first day when you turned on your Looko2® sensor !
We are running more than 2k sensors now. Some of them are kept in secret locations (yes – they are not available on the map), some in really cool places like bridges, lamp posts, schools, kindergartens, inside high-tech solar benches in Dubai, on Taxis (measuring pollution during the ride).
One thing is key – it is YOU to decide where to install it. Exactly where you want it. It is the time for our product to be available worldwide. Available for you. Looko2® is your personal air quality sensor.
Looko2® selected features:
Laser based air quality measurement
WiFi enabled device – connects to specified by you network and sends data
Every minute live data published to server
Automatically generated reports for historical and trend analysis
Bright LED color 5 level threat visualization (blue – very good, green – good, yellow – moderate, orange – satisfactory, red – bad, dark red – hazardous)
Displays live data and stats on dedicated for your sensor webpage
Works with Android and iOS mobile apps - see here: Looko2® supported apps
It requires 5V (USB-C) so you can power it from alternative/green power sources.
Looko2® have built in WiFi card - you can install it in most convenient place for you (supports WiFi type 'b')
Weatherproof (-30C to +60C) - you can install it outside without any doubt.
GPS position - provide GPS coordinates and show others what is the air quality exactly where Looko2 is installed.
Works perfectly with smart home / home automation that can enable your ventilation or air purifier when needed due to it's open API architecture
Tested in various smaller or bigger cities - support Smart City easy installation
Super easy to install due to step by step quick manual
Free API, reports and NO NEED TO PAY ANY MONTHLY FEE
You can add premium services that allows you to receive data directly on your server!
What comes in package ?
Useful links:
Looko2® Sensor Readout Example
Enter your email address if you'd like to be notified when Looko2® Your Personal Air Quality WiFi Sensor can be shipped to you:
$199.00
$589.00
$79.95
