Arkanoid is a pocket optical theremin
Designed by DIYSynths&Sounds in CzechiaNo shipping info available.
Arkanoid is a lofi optical theremin based on the 556 timer chip which allows you to create haunting and drone sounds without touching! It is very sensitive to light. You can control pitch and depth w…
Read More…Arkanoid is a lofi optical theremin based on the 556 timer chip which allows you to create haunting and drone sounds without touching! It is very sensitive to light. You can control pitch and depth with the intensity of light. More light = higher pitch. It also has CV inputs, one for pitch and one for depth. Powered by 3 AA batteries.
Enter your email address if you'd like to be notified when Arkanoid can be shipped to you:
