ESP32_grbl CNC I/O Module to drive Spindle Controllers with a 0-10V Input.
What is it? This a 0-10V spindle controller CNC I/O Module designed for use with our 6 Pack compact CNC Controller. It can be used to control your 0-10V input speed controller. the module also has …
Read More…This a 0-10V spindle controller CNC I/O Module designed for use with our 6 Pack compact CNC Controller. It can be used to control your 0-10V input speed controller. the module also has (2) opto isolated outputs. These can be used for direction signals and other features.
This is our original PCB design, based on Bart Dring with some minor changed to adapt to our need.
DESCRIPTION This module is 100% compatible with Bart DRING module : It has a 5 position terminal block Offering 2 opto isolated outputs and 0-10volts signal.
WHAT IS INCLUDED
ORDERING
Please note that this item is to use with our 6 pack compact modular controller available in our Shop
Enter your email address if you'd like to be notified when 0-10V Spindle CNC I/O module can be shipped to you:
$105.00
$33.00
$41.00
$29.95
$19.95
