MODULAR 3 CHANNEL PWM POWER CONTROLED LED plant hydroponic agriculture
What is it? This is a modular 3 channel PWM controlled LED PANEL with a WS2811 controller. Using this panel you can make your own DIY hydroponic systems. This panel has been designed for Hydroponic i…
Read More…This is a modular 3 channel PWM controlled LED PANEL with a WS2811 controller.
This panel has been designed for Hydroponic illumination with especially selected Wavelength
The purpose is to control the intensity of light for each colour (Red, Green, Blue), so you can vary intensity and duration to simulate the different phase of daylight but also the season to stimulate and increase your production quality and throughput.
The panel embed totally 84 x 0.2 WATT LED
The Best Full Spectrum Blue: help plants grow Red: help plants grow and bloom, red LED is the key to flowering plants Infrared-2 LED: Infrared can help plants grow UV: UV can help plants grow and kill insects. We have made a special design and added UV and IR LEDs according to the plants needs. More similar to sunlight and more suitable for plant growth. We add the green LED so you can see in "natural light colour" for display or any care
using the control for each channel, you can create The most appropriate light ratio to increase the yield of commercial cultivation, which can be used in all stages of plant growth and flowering.
Specifications:
Use for:
Energy Electricity Saving with Higher-level Efficiency. Full spectrum that is necessary & critical for plants growing & flowering (from seeding to harvest) Perfect for small Grow Box, Grow Tent, DIY Hydroponics, Bonsai, Garden... etc High-performing, long-life lightning
WHAT IS INCLUDED
ORDERING
Please note that this item needs a 24V controller and 24-volt DC power supply to run, some are available in our shop or you can build your's own with ARDUINO board for example
SPECIAL REQUIREMENT
This panel has been also used for some light therapy
Upon request, we can also make special arrangement depending on your need (wave length, other combination and more power
Enter your email address if you'd like to be notified when 3 channel PWM LED plant hydroponic agriculture can be shipped to you:
1-9 | $55.00 |
10-24 | $48.00 |
25-49 | $45.00 |
50-99 | $42.00 |
100+ | $40.00 |
$105.00
$33.00
$41.00
$6.50
